ryno1234
- Joined
- Dec 8, 2014
- 165
This is going to be a rather detailed sequence of events, so hang in there:
I just replaced my carburetor with a new Rochester Quadrajet. I was previously having issues with my engine refusing to start after boating for 15+ minutes. This was random, so I threw money at it and bought a new carb and new spark plugs.
I got the new carb, installed it and tuned it (to the best of my ability) using a vacuum gauge.
It started and ran great in the driveway.
I took it out today to the lake. It needed 2 prime pumps of the throttle to put gas into the intake. After that it started right up and never died while idling at the dock (something which it did not do well previously). This was a good sign.
I took it out in the 5mph zone for 15 minutes, shut it down and attempted to see if it would start up again in an attempt to see if we had progress. It started up just fine, first try.
I then took the boat out outside the 5mph zone and went a *little* faster for about 5 minutes, all was good.
Went for full throttle and as I advanced the throttle, the boat seemed to accelerate and at a certain point almost choke on itself and the acceleration would slow / stop and I'd get a backfire coming from the intake manifold.
I was unsure of what I was hearing so I tried this a time or two. I realized while doing this, I could back off the throttle as the boat seemed to choke / stall and almost "save" the stall. I began to think that this may be roughly when the secondary butterflies open. Maybe the "stall" was those opening (not sure though).
The backfire concerned me so I played around with timing while out on the water. I tweaked the distributor slightly in either direction. One direction seemed to help more than the other by eliminating the backfire, but I would still get the stall that would happen eventually. Some adjustment to the distributor *seemed* to move the stall point further up throttle position than others. I could be wrong though.
Alas, none of these changes fixed the problem entirely and some of them resulted in backfire through the intake.
Furthermore on one of these times, I heard the stall and instantly pulled the throttle back (to avoid a backfire) and turned the engine off almost in one motion.
After this, the engine had a difficult time starting, but would eventually start if I advanced the throttle and left it there while attempting a start. I'm speculating but I'm thinking this action may have flooded it.
I then tried to adjust the mixture screws wondering if I was running too rich. My understanding was that these were for idle only, but I wanted to at least see if they had any bearing on throttle positions beyond idle. I tried to lean the mixture by a half turn.
This didn't seem to help much but I could be sure at this point because I was now having difficult event starting the engine.
I played around with different timing settings and returned my mixture to where it was to start. At this point I couldn't get the boat started at all no matter what over the course of 1 1/2 hours.
We pulled the boat out and I took it home.
Once home, I hooked it up to earmuffs., and attempted to start it (without priming it). I could tell it wanted to catch, but never did until I advanced the throttle 1/2 way. At this point the engine started but sounded awful. It sounded like it was stumbling. It wasn't a smooth idle. Sounded something like a race-car at the track. It wouldn't idle for more than a few seconds if I returned the throttle to idle.
So, I have a few ideas that I have not fully fleshed out:
As you all know, the season is coming to an end and I have missed most of it working on the boat. Any help to soften this blow would be appreciated.
- I have a timing issue
- I have a mixture issue
- I have destroyed something with my 3-4 backfires.
