nola mike
- Joined
- Apr 22, 2009
- 5,960
Went about 40-50 miles last weekend for the first trip of the year, and the boat sat on a mooring for 4 days. Pulled the plug after I hauled it out, and had milky gear oil. A1G1 outdrive. I had pressure tested the drive prior to putting it on (both halves independently, and then when assembled), and it was OK. Drained the oil, pressure tested again, and again it seems to be holding pressure. Rotated the prop, no change. Usually when I've seen the leaks, the pressure is lost quickly at 15 psi. If it's a super slow leak, I can't imagine how I'll find it...any tips? In the meantime, if the weather cooperates I'm going to refill and see what happens.
