Does My Boat Have a Ballast Resistor?
isaacs
I recently had some engine troubles and considered installing a new coil. The coil I bought said "For use with external resistor". I don't see a ballast resistor but I'm reading about resistor wire. How do I know if I have this?
As it turned out, there was nothing wrong with my original coil and with the installation of a new sensor in the distributor all is well, I'm just curious; if there's no resistor how do these things handle the voltage draw-down during starting?
This is a 5.0L with a Thunderbolt V ignition, SN 0M092219.
TB5 ignition doesn't use a resistor wire or external resistor. You would use a internal resistor coil. There is no issue with voltage draw down, uses full 12V during starting and running
isaacs
What is an internal resistance coil, how does it work?
