RaceCarRich
Thread starter- Joined
- May 31, 2015
- 234
Topic has been sort of beat to death and I've done a lot of reading and searching here over the years. Even so, it's an important enough decision with VERY severe consequences that I have to ask for opinions. I know thousands of people do either of my outlined methods each year and that I'm probably over-thinking this but I don't want to learn the hard way. I'm a well maintained 5.0L MPI/Bravo3 raw water cooled with what I believe is called the 3 point drain system.
I know conventional wisdom is air doesn't freeze (I get it, that's how I used to winterize my old 3.0L) and that the block drains often clog (I also get that as I removed the single point drain on my old 3.0L and would poke the clogged block drain). Let's assume that I can't get to the block drains on this boat (at least without removing manifolds at minimum). Would you:
A) Pull the 3 drain plugs and one vent plug to drain water then reinstall. Next get one of those kits that sits on the swim platform and feeds antifreeze through the muffs until the liquid exiting the drive while running is pink? Even then I would continue to run more gallons through just to be certain and dilute any possibly remaining water.
or
B) Pull the 3 drain plugs and one vent plug to drain water. Next pull the big hose off thermostat housing and fill with a little antifreeze until I witness it start coming out the drain plug holes (just to confirm it is getting through the block drains). I would then replace the drain plugs and fill the big hose until pink starts coming out the thermostat housing. I would probably continue with another gallon just to be certain and dilute any possibly remaining water. I would reinstall the large hose and pull the two smaller hoses going to the manifolds. Fill each small hose (again perhaps overfill) and then reinstall the small hoses.
In either case I would be on the lookout for danger signs like not much water draining when the blue plugs are pulled.
or
C) Absolutely refuse to use either A or B method and would rather pull the motor if necessary.
Thanks for your opinions. I know many of you must be sick of giving winterizing advise multiple times each year although I did search and read which is how I even came up with these two plans of attack. The rest of winterizing I got down pat (changing engine and drive oils, changing fuel filters, sink lines, etc.) its just the engine freeze protection on this setup that I've never done before.
or
or
