sms986
Thread starter- Joined
- Sep 18, 2017
- 334
I have been in desperate need of a new boat for a long time. I have an '87 duracraft jon with a with a '63 40hp evinrude on the back. The boat is SMALL.
I want to finally buy something that I will not have to worry about fixing something on or getting stranded on for a very long time. However, new boats are insanely expensive. What's better is that some people think the value goes up after they've used them for a year.
so I decided to save money and build myself a boat. I want an aluminum boat, because I fish a lot of shallow rocky areas. I also want plenty of room so I never fall off again. Last, I don't need to break the sound barrier. I'll be thrilled to have a boat that goes 50 max.
Here's what I've come up with. I'm going to order a custom made aluminum 2272 boat and put two '98 yamaha gp1200 engines on the back. I've got a few questions and want to hear pros and cons.
First, I do want to say that I'm using the two yamaha motors because I want a jet drive for shallow river running. I know that they are '98 models but I really like the yamaha two strokes. In fact, I have a gp1200 jet ski now from '98 that has never been rebuilt/tinkered with/repaired. It runs like a top. I also got a great deal-unbeatable by a comparable outboard on the donar skis.
Now I know that two 135 hp jet ski engines sounds like overkill, but if you factor in the 70% power loss with a jet drive, they're 90hp each. If a 40hp can only push my 15' jon 25 mph bare naked, I doubt the single engine will be any better on a 22' loaded down with my gear. Second, I don't drive like a maniac. I'll probably only be top speeding to get up rapids and on long straight stretches. And last, if I have two engines, I can run miles up into the wild and not worry about getting stranded (unless I'm double unlucky).
So the only question I have right now is if a flat bottom mod vee would handle ok at 50, or if I should go with an 8 degree vee. The flat bottom has strakes, the vee does not.
I also want to hear your opinions and pros/cons.
Thanks!
Thanks!
