Torque specs 2009 SX-A prop shaft brg holder
Pudawaa
Anyone have the specs for these two bolts ? I’ve been told 10 ft/lbs plus 70 degrees...
muc
"Retired" Association of Marine Technicians...
That’s the spec for checking rolling torque with the old bolts.
During final assembly you use new style bolts and torque to 15-20 ft. lbs.
Pudawaa
I was concerned about the torque spec because the heli inserts had come loose (stripped) and the prop shaft brg housing was about to fall out ...
