Electrical short 4.3 Mercruiser 06Tahoe
tlmoore62
I have a 15 amp fuse that keeps blowing back by the distributor. This causes me to loose all power and kills the motor. Progressively got worse and now blows as soon as I turn the key on. Any help appreciated!!!
When asking a question always best to provide the motor serial number, this way we know what your working on
The 15 amp fuse should be 12V main power. Things that draw direct from the fuse are the main power relay (MPR), power control module (PCM), idle air control (IAC), and throttle position sensor (TPS)
Disconnect the IAC and TPS to see if fuse blows. If it doesn't, reconnect one at a time and try again.
tlmoore62
Thanks so much for the reply, can you help me with locating where to disconnect TPS and/or IAC? Thanks
The TPS is on the throttle body (TB), the IAC is either on the TB or the intake
Again, I need a serial number
Thanks
You don't have a IAC or TPS, you have TKS carb.
Normally when the fuse blows it just keeps the carb running rich, but it does keep running. For it to start killing the motor I would look at the temp switch and the TKS module
Verify you have a carb that looks like this
tlmoore62
this looks correct, when the fuse blows, it will not crank, no power to anything until I replace it.
The TKS has 2 power feeds which can power the ignition. The TKS fuse and the 20 amp fuse from the key switch (not shown in pic)
This is a simplified pic
tlmoore62
Im sure of what fuse is blowing, but not clear on where to start with finding the short causing it to blow. Any direction on where to start? The 15 amp fuse back by the distributor I'm assuming must be the TKS fuse?
Fun Times
Over the years we've had some TKS fuses burn out and here are a few memorable ones that may help give some indications of where to look for some other general ideas,
But from the descriptions, and the boat model and engine combo, It sounds like maybe the 15 Amp fuse isn't part of the TKS system but more of what is sometimes called the Clean Power System coming off of the 10 pin cannon plug area and this fuse is considered hard to find do to location.
To know if this may be the case, please have a look at this post with photos to see if this may be what you're after and where you found the blown fuse...If so then there have been roughly 3ish other types of similar issues over the years since this thread was made.
#65 = https://forums.iboats.com/threads/hidden-fuse-on-4-3-tahoe-q4-please-help.536975/post-3863038
Edit update, if you happen to have a newer engine model which in this case included an MPI, then see post number 5 for a photo solution,
Saved here in case it goes away…,
tlmoore62
That is the fuse that I am having the problem with. It took me a half day to find it, once I replaced it, it fixed the problem for a few weeks, then blew again. I think I found the issue, a couple years ago when I took the boat in to be winterized, the mechanic said he couldn't keep it running and had to jump a wire around the main harness connection. I found that the jumper wire connection he installed came apart and was shorting on the block. I took the harness connection apart, cleaned the pins, spread them a bit and reconnected. Everything seems to be working fine now. Thanks for all the help and direction, these electrical problems eat my lunch!!!
Fun Times
Glad you found it and was able to solve the problem.
I'll add that if you happen to use an bigger amperage draw device such as an Air pump for a inner tube, etc., and use 12v power from the helm area such as a cigarette lighter adapter with plug design then it's been known that a 15 Amp fuse there may be to small and blow often and going up to a 20 generally helps stops blowing the fuse right away....But be extra cautious feeling for heat to the wires and try not to run it continuously.
