AMMO DAWG
Thread starter- Joined
- Aug 3, 2012
- 227
I have a 2006 Sea Ray 185 Sport that I am repowering with a 4.3, previously had a 3.0. I had in the past removed and reinstalled the 3.0 and noticed one of the front motor mount lag bolts wouldn't tighten. I had asked in several places and contacted Sea Ray and never got a straight answer on the construction of these mounts. Lots of speculation related to no wood, but couldn't find anywhere for this year boat where someone had done a repair.
I decided best to tear into it to be sure there is something solid to bolt into before installing the new engine. Sure enough when I cut of the top there is a piece of wood inside, 1.5" lumber. There was rot when the bolt holes had gone in, guess water seeped in over the years. The starboard side wasn't so bad, the port side was shot. Odd part is the wood is not glassed to any other structure, It has foam below it and on all four sides, I assume the glass tower it self is the structure, the wood is an anchor for the bolts. I replaced the wood and looking for advice on how may layers of glass to use. I'm using 1708 with poly. The piece I cut out was about 3/16" to 1/4" thick. I attached some pictures. I was thinking four to six layers with several inches overlap.
Question for the experts, how much load goes into those front mounts with the rear of the engine firmly bolted into the transom plate? I know it's probably rotational, just never seen any posts where engine mounts had failed to a point of letting the engine shift or rotate. BTW, when I rebuilt the back end, gimbal housing the transom was solid with no rot. Looking forward to you advice.
