cjwagner1962
Thread starter- Joined
- Jun 4, 2017
- 5
HI all, hoping you can help sort out this electrical gremlin.
2003 Chaparral Signature 240.
Interstate Flooded Cell #1 starting and #2 deep cycle house. new May 2018.
Battery Charger Pro Mariner Pronautic 1230 P installed 2018.
Fusion Stereo installed 2017 on NMEA 2000 backbone.
Guest 2433 P Galvanic isolator. Probably original.
The boat only has 300 hours on it. It is not wet slipped. Most wiring is factory except the NEMA backbone and drops I installed a couple of years ago.
Last trip out we were overnighting at a marina, hooked to shore power. Woke up to nearly dead batteries. Battery charger was in fault mode. Took the boat for a cruise and batteries charged through the altenator no problem.
Got the boat home and found a bad inline 60A 32V glass fuse between the battery charger negative output and the battery ground post. The fuse wasn't blown, just didn't have continuity. Replaced it and the battery charger seems fine now but here is the weird thing.
The stereo and galvanic isolator are located in the 120V cabinet. These are the only 2 devices in that cabinet that need 12V power. From the factory, the stereo 12v and the galvanic isolator 12V positive are crimped to the 12V positive coming from the helm 12V fuse block. This positive power wire does not get power unless I have 120V shore power plugged in and the battery charger 120V switch is on. If I turn off the battery charger 120V switch, I loose 12v power to this postitive power lead. This does not effect any other 12V systems on the boat. I don't believe its a direct short circuit or the 120v power would have surely blown up the stereo and galvanic isolator.
Please give me troubleshooting steps.
Thanks in advance.
Chris
Thanks in advance.
Chris
