block in heads are the same, however the cam is marine specific, the circulating pump is marine specific and the fuel system and ignition is marine specific along with the accessories on the front. marine 8.1 oil pan is a full-sump unit vs the automotive rear sump.
are you buying a complete bob tail or just a long block?
if you are buying a long-block, buy it without an automotive water pump, ditch the cam, install a marine cam and transfer everything over.
