fmt2bx
Thread starter- Joined
- May 27, 2015
- 217
Hi,
I got this motor transplanted to our boat. It has a fresh water cooling system. Towards the rear of motor is the VST. Out of the VST is a small barb which, if I am not mistaken, should be connected to the thermostat housing. the motor came with no connection to the barb.
Could someone tell me where should the tube from this barb should be connected to when using a fresh water cooling system? Is there suppose to be some kind of check valve to prevent water from going to VST?
Here are some pictures... (There is a small hose connected to barb right now with a small yellow cap at the end)
Thank you.
Thank you.
