2006 Polar Kraft 182 FF
jbcurt00
If I had to guess
Bilge drain plug
Livewell fill
Livewell drain
TerryMemphis
When we ran it today the middle plug ( I am assuming is the hull plug ) was dry
The starboard side was dry and the port side poured a lot of water out
Do the live wells drain into a “channel” in the hull that then drains when you pull the plug?
ahicks
This is an aluminum boat, right? USUALLY, the area just ahead of the transom is able to be opened up pretty easily so you can get a pretty clear idea what each of those 3 openings do.
TerryMemphis
Aluminum yes
when you open the hatch next to the transom that compartment has three batteries and the charger it seems to have a flat bottom that is raised and it not the actual bottom of the hull
ahicks
Aluminum yes
Look just to the rear of that flat panel. See if there isn't access to the bilge there.
