470 Distributor Mechanical Advance
tmccotter
Hello!
I've recently acquired and rebuilt a 3.7l 165. All is good at lower RPMs but under load and over 3K rpm I hear a clacking sound which I believe to be detonation. I believe the issue is excessive timing advance from the mechanical advance.
I measured the advance at 500 rpm increments up through 4K rpm and compared it with the timing curve specification. I can see that the advance climbs correctly with the curve and doesn't flatten out at 2K rpm per the specification but rather continues to increase up to up over 40 degrees. Most mechanical advance mechanisms have something limiting the total advance but I can't find any documentation for the distributor.
Does anyone out there know how to limit the mechanical advance? Is there any documentation for these distributors?
This is the first question I've asked but you all have answered at least a thousand questions I have had through these forums..... thanks!!
Tom
Bt Doctur
I`m not positive but I think the innards are GM 4 /6 cylinder dist parts
tmccotter
Thanks so much for the speedy reply! It is still points... new points, rotor and condenser were installed during the rebuild. I examined, cleaned and lubricated the distributor during rebuild and didn't see any issues. When I was cleaning it up I didn't break down the advance mechanism so I don't know for sure how it works. Other distributors I've seen have a shim or something that stops the weights from traveling further out past the maximum advance but I don't know what happens with these distributors.
I also looked at the equivalent part from Sierra and Delco and I can't find any documentation for those either.
Lou C
If it’s like a Prestolite under the point plate there are a pair of flyweights that are retained by springs. When the engine speeds up the flyweights move outward due to centrifugal force and advance the position of the rotor which advances the timing. Then when it slows down the springs pull the flyweights in which retards the timing. So if it’s advancing too much the springs may have weakened. Or corrosion may be causing the flyweights to stick. You can remove the point plate and clean and lube the flyweights and re test. If it’s still too advanced see if you can get a new set of the correct springs.
see how much slop is in the $5 distributor shaft bushing from napa
also, if you didnt set your dwell with a meter, go back to that, then set timing
tmccotter
Right, the timing does advance as you described. I think it is possible that the springs have weakened; however, the advance follows the curve as rpms are increasing and then just keeps going. I can't find any specs or description of the springs but I will try to find replacements. I did clean and lube the flyweights already, they aren't sticking.
Right, the timing does advance as you described. I think it is possible that the springs have weakened; however, the advance follows the curve as rpms are increasing and then just keeps going. I can't find any specs or description of the springs but I will try to find replacements. I did clean and lube the flyweights already, they aren't sticking. I was really curious as to whether there was something that limited the maximum advance.
tmccotter
dwell and timing are good. To which bushings are you referring? I looked at the parts diagram and I can't figure out where they are.
Pull the dizzy, knock the roll pin out of the gear, pull the inner shaft, look in the housing. All dizzys have bushings, and napa has generic bushings for dizzys cheap
you dont have a billet distributor, you also dont have a sunnen distributor machine to set the distributor up
tmccotter
The kit has several sets of springs. Currently, the centrifugal advance is over advancing. Either tighter springs or something to limit the advance would be the likely solution. For $15 it seems like a reasonable thing to try. As I mentioned earlier I can't find any documentation or replacement parts (nor a parts diagram) of the current distributor so I need to experiment.
Lou C
Why not look around and see if you can find the original springs that it came with? I was able to find an original set of springs for mine and its 32 years old....
tmccotter
I'd like to do that but I haven't been able to find any sort of part number or description of the springs. Mine is 32 years old too. How did you find yours?
you cant use springs from one manufacturer and expect them to work on another manufacturers distributor and expect them to work. only way to "experiment" is with a sunnen distributor machine.
Lou C
I looked it up in an OMC parts manual! Found them on another site I can’t post it here but they were still available so I picked up a set of springs, new point plate etc. I also picked up a spare Prestolite for my 4.3... eBay....
GA_Boater
Thank you for not posting the link, Lou.
What you can do is post the part numbers if you still have them. All tmcotter needs is new springs and he can Google the part numbers.
