tricountytrail
Thread starter- Joined
- May 31, 2014
- 22
I tore up my seal when I last installed my lower to upper drives. I think I might have had the wrong oring (it was a little loose I had to force the drive up to fully seat)? What seals the drive shaft into the spline? There is a hole on the top of the spline the driveshaft goes into that would mean the cavity is full of oil that doesn't seem correct?
Also which way does the lower upper seal on upper housing on the driveshaft face, install seal spring side up or down??
