fmt2bx
Thread starter- Joined
- May 27, 2015
- 217
Gm350 TBI engine. Idles fine, if I apply throttle gently, no issues. However if I try to do a hole shot, motor hesitates, misfires or backfires (can't tell) then accelerates normally.
Also while at 4400 Rpm if I go to neutral rapidly, no misfire or backfire. Works fine.
The only issue is Hole shot.
I did some research on the net but I was wondering if someone could give me a step by step troubleshooting list.
Here is what I have done so far:
- New plugs
- New distributor cap and rotor
- Took the TBI apart, cleaned, replaced with rebuilt kit and replaced the injectors
- Fuel tank is cleaned refilled with 89 octane ethanol free.
- VST removed and cleaned up.
This motor is new to me, I do not have any previous experience with it.
Thank you.
Frederic
- New plugs
Thank you.
Frederic
