Bt Doctur
Thread starter- Joined
- Aug 29, 2004
- 19,558
This is my personal boat and have been working on it for about 2 years. 4.3 ,mechanical fuel pump, rochester 4 bbl. Needed to do a haul so I needed to get off my trailer. Motor would not idle so I did a quick and dirty quick cleaning and had a stable idle. Put the boat in the slip , did the haul and took it out for a test. Good 2 barrel performance but starving with the throttle opened up. The second run did good at the higher speeds but carb was flooding out at idle. Stumbling, black exaust, etc.Expected as much for sitting 2 years.
Replace it with an edelbrock that was new and had been borrowed for a week until the customers carb came back. No issues at all on my customers motor.
Put it on my motor and when cold runs and idles perfect. When hot runs good at above idle but will flood at idle. Mechanical pumps are not supposed to increase fuel pressure
but this has one stumped. Was going to test with an electric pump but the weather closed in on me .
Any thoughts?
Any thoughts?
