Used gimbal installation
Galvez83
Hey folks i have a question regarding a used gimbal housing that i bought to replace my broken one. Both are Bravo gimbals. The new (used) unit has 2 square holes on the bottom where the one on the boat does not have that option. The question being, are both the same gimbals
GA_Boater
This purely my opinion - I wouldn't re-use a used gimbal.
If you want us to offer advice, it would help to do what you're working on, again my opinion.
Ayuh,..... What, Exactly, are you callin' the gimbal,..??..??
There's alota bits to a gimbal assembly,......
GA_Boater
Good question, Bondo. I may have wrongly assumed the bearing.
Galvez83
Just the gimbal housing not the bearing or bell housing. The gimbal is cracked where it meets the transom. So i had to go out and get a used one.
Ayuh,..... Have ya got a picture of the square holes,..??
Galvez83
Here are the pics of the broken one on the boat vs the new on with the square opening
Ayuh,...... That's where the aluminum anode blots go through the transom,.....
No difference,......
