Yamahahahaha
Thread starter- Joined
- Nov 11, 2020
- 4
Bought my 1990 4 hp yamaha 2 stroke used . It runs fine ( idle and in gear ) in the back yard on the hose and idles fine on the boat . When I throttle up in gear the motor will run up to good rpm for a short distance , then bog and stall out . It starts right back up and will repeat the issue over and over . It had a under cowl tank that I've cleaned thoroughly , I've rebuilt the Carb , checked the reeds and replaced all associated gaskets but , I'm still having the same issue . Any ideas on where to go next would be greatly appreciated !
