bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
Hello I have a 1999 Johnson 150 Ocean Runner. Ive had it about 4 years now, has usually ran very good. I replaced the fuiel tank just over a year ago, I have top quality fuel hose from Shields. originally I had an in line filter PLUS the water seperator . last year i removed the inline filter. earlier this year i checked the white filter on the front of the fuel pump. it was clean..... once...in a while at 4000-5000 rpm the fuel restriction (check engine) like would alarm.... and if I backed down the throttle it always went away. Yesterday I was going off when ever I tried to run over 2000 rpm. I could run it up to 3000 and within 20 seconds the alarm would sound.. motor sounded fine... water temps were fine...but id back down the rpm to remove the red light( the alarm only sounds for about 10 seconds). SO, my question is ..IS THIS A SIGN, my fuel pump is getting weak ???? I have it blocked off and use premix oil-gas fuel. The fuel tank is 15 feet away from the motor. I dont know if that distance makes the pump work hard.... Thankls in advance
BOB
BOB
