highpowerdad
- Joined
- Feb 5, 2020
- 97
Hello again, so I have a question about how my 2005 5.0 GXI is starting. On the first start of a cold motor, it instantly turns over (starts), but then in about a second, stumbles, almost stalls and then catches itself and revs up to about 2K rpms and then settles down to 600ish rpm idle speed. After that it is fine, restarts "normal" and goes right to idle all day long. Then when starting cold the next day or a few days later, the cycle seems to repeat with start-stumble-rev-up-settle to idle. It has done it for a while now, I have replaced - as part of normal maintenance, cap/rotor/wires and plugs, with no change in the behavior. I am getting ready to change the fuel pump since it is whining pretty loud, but I don't think that is causing this problem, though I am guessing it is starving for fuel - or air, right after startup...
Thanks
Scott
Thanks
Scott
