fishing gypsy
Thread starter- Joined
- Oct 29, 2017
- 1
I have a 2004 Mercruiser 350 MPI. in a Bayliner 288 Classic Cruiser. This boat is new to me. I took it out for only the second time since purchase and on startup both upper and lower station oil pressure gauges read 40 psi at about 3900 rpm. After running for 15 minutes the gauges started fluctuating from 0 psi to 40 psi. Then after another 10 minutes they both fell to 0 psi. I stopped the engine and checked the oil and it was at the full mark. Temp gauge (coolant) read 180 degrees. Oil temp gauges read 0 degrees. Restarted engine and gauges showed good oil pressure. Ran for 15 minutes again and lost oil pressure readings. I am thinking this is a problem with the oil pressure sending unit, but looking for the input on this. The engine is equipped with Smartcraft.
Thank you for any ideas.
A Wesley
A Wesley
