Professor lounge chair
Thread starter- Joined
- Dec 19, 2020
- 6
I recently had a rear drain hose pull off the fitting leading to the outside of the boat in the bottom of the transom.
Upon trying to attach it back I found it to be almost an inch shorter and could not reach the fitting the hose clamp was still intact on the hose.
I've since found that this drain hose can shrink after time and actually pull off of the fittings or tear.
Upon doing a little investigation I found that Sea Hunt had an issue with drain hoses shrinking and comming loose.
My question is has anyone experienced or heard of this type of incident?
