Handyman72
Thread starter- Joined
- Oct 12, 2020
- 37
Gday all
After alot of replaced parts and time spent,im now seriously thinking of a rebuild.
My engine is 1970 60hp 60073D electric shift
Rebuilt gearbox
Rebuilt carbs
New plugs,coil,
I did a compression check after all this was done
No 1.......65psi
No 2........75psi
No 3........70psi
The distributor cap has a few grooves and marks inside that are deep
The rotor has like a crunchy ring that looks like burn around the same area as the ignite point,
The distributor also has a bubble and slight melt on the inside going from the coil wire point all the way around.
At this stage to replace with another engine later model in Australia would cost approximately
$4500.
Am I better off rebuilding or replacing
Cheers
Rebuilt gearbox
Rebuilt carbs
New plugs,coil,
No 1.......65psi
No 2........75psi
No 3........70psi
$4500.
Cheers
