KirstyBain
Thread starter- Joined
- Dec 23, 2020
- 13
Unfortunately, we have no history on the boat. Belongs to a client of ours. Bill of sale does not name the make or model and the HIN used on the documentation, is as per the above plate. Which we know is not correct.what does the title say. that is not a correct HIN plate.
Thanks, I will take a look. I searched over the transom area for another HIN, that may be the actual one, but could not find anything.Down in the bilge area many boats have a hull number plate down there someplace. Not all do but its worth a look.
LA-31FLY-84-01O5 This is the complete number.Far from an expert on non US or Canada HIN's but this does look similar to European HINs I have seen in the past. What is the whole number as the photo seems to cut off some of the plate.
I had a look today and could not find any other identifying numbers. I also looked through all the paperwork on the boat. There were a lot of chart purchases for the Philippines. The boat is currently in Dubai UAE! So could have been imported from Philippines?Thanks, I will take a look. I searched over the transom area for another HIN, that may be the actual one, but could not find anything.
Did a little research and European codes consist of 14 alpha numeric characters but many foreign countries us a similar system. FLY is the manufactures code forI had a look today and could not find any other identifying numbers. I also looked through all the paperwork on the boat. There were a lot of chart purchases for the Philippines. The boat is currently in Dubai UAE! So could have been imported from Philippines?
| USA YACHT LTD | 655 MAID MARION HILL | SHERWOOD FOREST | MD |
Thank you very much. I will look into this further and let you know if I have any success.Did a little research and European codes consist of 14 alpha numeric characters but many foreign countries us a similar system. FLY is the manufactures code for
USA YACHT LTD 655 MAID MARION HILL SHERWOOD FOREST MD
The first two letters may be the country code. Could be Latvia or Laos.
Don't know if US Yacht, Ltd is still an active builder but that may be a start Good luck.
I agree. The engines were replaced. I do not know what they were before. They are now 2 x Volvo Penta KAD300 Diesel 285HP engines.That boat is not a Larson and it appears much older than 1989. Something about it just doesn’t look right, kind of like some one did their own work on it. Can you tell us anything about the engines and out drives. That may provide clues about the boat.
This is the Westerbeke generator serial numbers. I have approached Westerbeke dealers in our region the request some details on the generator. In case it is the original.
