converting to hydraulic steering
J cubed
I am going to convert my Grady White 208 over to hydraulic steering in the spring and also install a Lowrance autopilot. Any tips or suggestions will be greatly appreciated. I have read that I may need to disconnect the outboard. I would like to avoid this if possible. Someone suggested cutting the steering rod in order to remove it from the outboard or cutting a hole in order to make a clearance. Does anyone have any experience with the installation of either of these units?
dingbat
I would opt for cutting the steering rod to remove. 4" grinder with the cut off wheel would make quick work of it.
Marathon Man
Look at Seastar (now Dometic) and also Uflex to find a model that utilizes a split support rod that goes into the tilt tube.
Thereby not requiring the motor to be removed.
I just did this with a Uflex.
