Delayed Ignition Fuel Pump
Ericd96
Hi, I am experiencing the same fault on my 2002 Mercury 200 efi.
- 20 second delay before fuel pump switches on and then continuous alarm
- No spark at spark plugs
- all fuses good
- Main power relay good
Any help will be appreciated
gm280
Well All I can say is Welcome aboard. Nice to have you as a new member. Since I have no experiences with your engine, I have on ideas or suggestions either. However, there are tons of iboaters on here that will chime in and offer you ideas and answers. Just let them read your question for a while and reply...
Ericd96
When the key is turned to "run" position, without cranking then the alarm beep does not sound and the main power relay does not click and neither does the fuel pump start. 20 seconds later however the fuel pump starts running continuously and the alarm sound continuously. The motor does crank when the key is turned further, but there is no spark on any of the plugs. I did an ohm test on the crank position sensor an it measured correctly.
