Douglasdzaster
Thread starter- Joined
- Sep 11, 2020
- 315
Hello everyone,
I have a new question. I recently replaced the entire fuel system which begins with a portable fuel tank. The new poly tanks are not vented which means I installed the recommended fuel demand valve as well as recommended sprayless fuel fittings. One of the new fittings is leaking already so I was sent a replacement. They come wrapped with what looks like Teflon and when I removed the old fitting this stuff was disintegrated. I carefully cleaned out the female threads to keep it out of the tank ( which I’ll probably dump and clean now anyway) I’ve found several bad reviews on these fittings so I think I’ll go back to OEM ones. Question is what’s best for thread sealant. I used Permatex ptfe on the water separator now I’ve read that’s not good, so I’ll probably redo it as well. I have read a lot about Permatex aviation form a gasket for fuel threads but is it safe for poly fuel tanks and will it work on npt fittings? Also I use only none ethanol fuel so that helps.
Thanks for any help. I’d really like to do it right this time as I’m almost finished with the carburetors thanks to the awesome help I’m getting and would hate to have thread sealant make me redo that job as well.
