Trevthefox
- Joined
- Sep 25, 2018
- 101
Hello everyone,
In a week or so I'm pulling the engine to replace a cam shaft in my '89 460 King cobra. While out in the water I noticed that my oil pressure would drop significantly at higher rpms. (sorry I don't have the specifics but I remember it was in the 40psi range at higher rpms). It worries me that I could ruin a brand new cam if I don't solve this oil pressure problem
1st step tonight was to run the engine and put a mechanical gauge on it. Per the manual the oil pressure should be at 40-60 psi at 800 rpm and 50 - 80 psi at 2000 rpm. My engine was at 53 psi at 800 rpm and 60 psi at 2000 rpm. I know the engine is falling within the the limits according to the book but should the psi be higher? One thing to note is that when doing this test we had to do it rather quickly so the engine hadn't fully heated up.
I just figured since the motor will be out we might as well replace the oil pump since it's pretty old. Will a standard pressure oil pump for a 460 suffice or does it call for a high volume/pressure oil pump?
