Sea Rider
- Joined
- Sep 20, 2008
- 12,345
Don't know if adjusting all 3 carbs to meet 15 mm setting it's a exact Mars science, there should be some small gap tolerance. That info should be stated in the Yam's 40 HP Service Manual which no one seems to have a copy to check that out. When the fuel pump delivers fuel will fill the carb's bowls under some pressure which should pass through the cleaned needle's seat passages nicely without effort.
Before assembling the carbs back on the motor, could check each carb individually. With carb siting on a flat surface connect a fuel hose direct on each carb's fuel entrance, prime the bulb till firm and check for fuel spills if any. On middle carb must close the other side of the T fuel connector for the test.
Positively sure that when priming the bulb till firm all the carb's needles will close nicely on their respective cleaned seat and previous fuel spills will be canceled forever. Fingers crossed!!
Happy Boating
Happy Boating
