highpowerdad
- Joined
- Feb 5, 2020
- 96
I don't know, that is a pretty steady "racket" and very consistent at the engine RPM just to be some clatter, but one thing is for sure, either it will stay the same and not mater, or if it is a worn joint or bearing, it is going to get worse...I am thinking what you are hearing is normal. Very common for Volvos to get some clatter in the top of the unit when at idle. Mine has had that ever since I owned it since 2002. Goes away when in gear out of the water when there is just the slightest amount of load.
anyone else have an SX drive that makes noise in neutral and then quiets up in drive?
