I'd like to invite everyone to participate in helping to rehab this old 18' Mariner: Whether a purist restorer or an old time "Rube Goldberg" your experience and thoughts are welcomed: The goal will be to splash around mid-June 2021 and it feels do-able: The boat was bought on Ebay from a Charity that specializes in boat auctions: (see my first posting..."Pig in a Poke"). At this point I have the floor mostly removed with some pieces under the splashwell that still remain: The Transom came out with relative ease and the gentle persuasion of a rubber mallet: I also did something different in regard to removing the inner and outer gunwale trim when removing the transom: I didn't remove any of it... Details and pictures to follow:
MY BIOPIC: I'm three years past my 70th year: Like each of you, I love being near, in or on the water. My earliest recollections are of the early 1950's and fishing trips with my dad out of Canarsie, Brooklyn on the big boats: My teenage years were spent growing up in Huntington Long Island and a stones throw away from the Harbor and a gazzillion memories. During college years at Stony Brook, I worked the Great South Bay as a bayman to pay for school. After graduation I continued to work as a clammer full time for the next 7 years until the bay was so depleted that it was hard to earn a living: Fast forward to December 2020; my phone is ringing...it's a friend...even before I answer it, I know exactly what the conversation will be: " What are you up to?" nothing much, what about you? Did you see such and such on Netflix, etc: I was ready to hang myself, so instead I bought the Starcraft: Goodbye Netflix hello Starcraft..! and I couldn't be happier: I'm able to devote as much time as needed to get the boat ready for some fishing adventures with my 6 year old grandson.
MY VISION: Is to have a SAFE platform for inshore fishing up to the inlet but never into the ocean: I will be using the boat exclusively on the Great South Bay of Long Island: I would like it to look good but not necessary to be awarded "Splash of the Year": I want the hull to be as light as possible and balanced: My thoughts are to move the fuel supply to the bow and the battery midships. Plus a bunch of other ideas:
REMOVING THE TRANSOM:
Here are some pictures of the transom being removed: I believe it may be the original transom..3 pieces and no indication of having previously been replaced: In doing my research here on the SC forum there was an abundance of help and detailed steps for replacing the Transom: Instead of drilling out the inner gunnel trim rivets and removing the outer gunnel trim: I took out my dremel with a metal cutting blade and in minutes the tab of aluminum that ends 3/4" over the transom was out and I was ready to pull the wood: All the cuts are invisible and covered by the end cap: Also, any water running along the top of the gunnel getting under the cap will spill directly into the side of the transom, so removing it makes sense, I think:
Tomorrow...I will be pulling the lower unit on the 1981 70hp Johnson and replacing the water pump: This engine has been in hibernation for 15 years: Details and pictures to follow: Have Fun..
