Keyboardman
Thread starter- Joined
- Sep 10, 2015
- 364
2000 Johnson 175 model# J175VXSIF I did a compression test of this engine and readings are are all over the board. Right side readings were 100 top 70 middle and 100 bottom. On the left bank they were 0 at the top, 50 in the middle and 100 in the bottom cyl. We did the test with all the plugs out and a shot of WD40 in each cyl. How could it be that one cyl has zero compression? I understand this engine has O rings instead of a head gasket. Can they just fail and cause these bad compression readings? Thanks
