neilly boy
Thread starter- Joined
- Jan 21, 2021
- 34
I have 1980 85 hp V4 evinrude. will not start unless its primed by spraying fuel into the cylinders. Once it starts it seems to run ok. It simply will not start unless its primed. Carbs are good, I took them apart and cleaned them thoroughly. new gaskets etc. electric choke is working . Fuel pump seems to work ok. Carb bowls were full when I opened them . Fresh gas . and good spark. I did a cold compression test that showed all cylinders were hitting around 90. Starts right up with priming. though it seems to run a bit rough at low idle. I looked at cylinders with an endoscope . there is some scoring evident on cylinder walls.
