William1979
Thread starter- Joined
- Feb 16, 2021
- 4
Need help identifying a mercruiser out prop
What about with picturesIt can't be done. Show it to your dealer.
You didn't post any.What about with pictures
Sorry I need to I'd the outdrive itselfI can see why you need help identifying a prop that isn't there. Must be a "Mirage " prop . I think if you can expand your question as in , I am looking for a prop for this outdrive it might help. But the caveat to that is , without knowing what boat it's on , what the gear ratio of the outdrive is or what engine is pushing the boat , no one can give you a guesstimate of what you need. Even with all that info we need your rated RPM's and what your hitting with a full load of gas and your normal crew to suggest what you need . Probably have to put a loaner prop on , start out with a 14 -1/4 or 1/2 x 19" pitch. That is the most common set up for a older Mercruiser outdrive.
That's what you should have asked for. Concise sentences always work well.Sorry I need to I'd the outdrive itself
