Trevthefox
Thread starter- Joined
- Sep 25, 2018
- 101
Hey guys! Yeah its as bad as it sounds. At this point I'm just trying to figure out what is causing this problem. Bear with me on this long story and please help!!
Backstory: Originally pulled engine to address a transom leak. While engine was out we figured we should do a once over and take it apart to see the condition of it. Having extra time during quarantine we decided to change some components: new cam, main, and rod bearings. New piston rings. We also re-lapped the valves and replaced the valve stem seals
Our mistake was not checking the lobe lift on the original cam and we replaced the lifters. We did an improper break in and ended up hearing some crazy rattling coming from the valve cover. Upon inspection we noticed a rocker arm was really loose on while the valve was closed. We took out the lifter and it was shaved off at a slant pretty bad. We wiped the lobe. Just this week installed a brand new cam from comp cams. Made for a marine 460. It wasn't an exact match but had a little bit of a higher lobe lift. When installing we did followed all instructions perfectly: comp cams break in lube, zinc additive, primed oil, oil was coming out of each rocker arm just fine. She started up right away and it sounded amazing. Got it up to 2500 rpm immediately. About 8 minutes into the break-in process we heard a rattle but it corrected itself almost immediately. Then it started to rattle more frequently but still intermittent. Cut the engine to think about it, and then decided to resume. At the 10 minute mark we went up to 2800 rpm and the rattling continued. Heard it coming from the valve covers. We decided to stop. After cooling down, we removed valved cover and intake manifold. The same lifter in the same lifter bore is shaved at an angle again. Lobe is probably wiped again. I couldn't even remove the lifter.
So what's going on? My conclusions are obviously the lifter isn't spinning if the lobe its wearing the lifter at an angle. Oil pressure was good so i'm pretty sure it was getting oil. Could it be a bad valve? Just a bad lifter bore? I'm lost. Machine shop is recommending just get a new block if we're having the same problem. I just don't want to get a new block and put the same heads on it and end up with the same problem.
