Mercrusier 5.7 no power to injectors!
toddsallee
I have spark, fuel pump working but no power to the fuel injectors. Any thoughts much appreciated! Injector fuse looks good!
12V is not present on the pink wire with ignition turned ON. Check fuses under cap (seen next to item 16)
Bt Doctur
click to enlarge
Using a different manual injector power and ground com from the ecm#21 is the main power feed, you need 12 here to start.Then at relay 14 you need 12 v. Fuse 16 is critical
toddsallee
Pretty much no voltage read!
click to enlarge
Thanks I starting right now to check power at the ecm#21
toddsallee
No Power at the ecm#21. Guess I need to replace that breaker. Question could that breaker be bad and still I have spark and power to the fuel Pump>
No, I did see there is 12v on the fuel pump. So I ran a jump to the injector and it sprayed fuel!
The fuel pump has nothing to do with the injectors. I wanted to know if there was 12V when the key is turned ON, with one of the wires on the injectors. One of them (pink or red) will have 12V when ever key is ON.
Th other side of the injector goes to the ECM and the ECM applies a ground to turn it ON
Its NOT the 50 amp breaker.
If you do not have 12V at the injector then go to the fuse.
Check for 12V at each fuse.
If 12V is on both sides of the fuse, then check the relay
toddsallee
Yes there is 12v on one side of the injector.
But the ground back to the ECM does not appear to be good! What does that mean. Thanks again!
ok then the ECM is not turning the injectors ON
When cranking do you see the tach show at least 300 rpm or maybe it doesn't move at all
See if you can find the serial number. Look above the starter for a plate on the block. What year?
If no plate, which ECM do you have
Is this a new to you boat, or did this problem just started?
toddsallee
F349479 serial Number Tach does goes up to at least 300 rpm
