BraydenAnthony
Thread starter- Joined
- Feb 14, 2021
- 3
Can short out the starter and get it to spin, no shock when done. Replaced ignition also. Nothing happens when key is turned.
Nodoes the selenoid click in START mode ??
Weathers been terrible, going to try this out tomorrow. Thanks!have a buddy keep your key on START and wiggle, prod all the wiring you can reach..especially in flexing areas also check neutral switch and safety switch
if you get a reaction you have a broken wire....time to whip out a test lamps or volt ohm meter
surgery and a soldering iron may be required
Make certain all connections to the battery , and motor side are clean
see diagram V4 from the 70s... may help clean all connections in the fat connector
still raining ...?Weathers been terrible, going to try this out tomorrow. Thanks!
