Force Chrysler 35 hp, pistons.
Vagelis
Hello everyone,
I have a force Chrysler 35 hp 1987” and I need pistons and rings 3 inches. Everything I found on eBay is 3.312 inches and etc. I can’t find 3 inches for my 35 hp. Can anyone send me a link? Or I have to throw this motor away? I also need to do a rectification to my cylinders about .010 .020 so I will need a little bit bigger pistons than the factory one.. thanks.
pnwboat
The pistons for that motor are unique and not used in any other models. That makes them very limited and had to find. You'd probably be better off finding a different complete used motor. If you are going to stay with a Force motor, a used 40HP or 50HP motor is better as parts are more available for them.
Vagelis
So my motor is for rubbish... thanks a lot!
matt167
you can source custom pistons, but you'll spend more than it's worth
Vagelis
Can you find me a link that I can find custom piston for this motor? Here in Europe there is nothing.
Wiseco start Chrysler force pistons from 40hp and over.. which means that they are bigger than 3 inches..
matt167
Many of the piston companies in the USA will do custom pistons. Weisco will do custom pistons and also do outboard pistons. they could make you a set. But will need your dimensions and might even need an original to go off of so they get it right. It won't be cheap
Vagelis
So I will throw it away and I will buy a used Yamaha to do my job.. thanks for your time!
Nordin
Vagelis try Franz Marine, he might have pistons and rings.
Yes he is in the US so you have them shipped to Europe and I think he is the only solution for your engine.
Vagelis
He replied my email today, thanks! 👍
Nordin
Franz Marine is in Grandview Missouri, I think you mean Mastertech Marine, they are in Florida and has a lot of parts for older OBs.
