rocketman63
Thread starter- Joined
- Feb 28, 2021
- 5
motor running great but have a little water coming out carb. Like milky fuel .Just in bottom two carbs But not in cylinders
1989 150 Hp Mercury black max V6 serial # 0c139831Gasoline needs heat to evaporate.------It gets that heat from the carburetor body.------Carburetor will be cold.----You might be looking at condensation.
Serial#0C139831 150 Hp black max 1989First and foremost, what are we working on? There should be a model and serial number plate on the motor. Get us a bit more info and I'm sure others will chime in with ideas.
top Two carbs show oil bottom one shows milky fuel coming out . Is there any way for water to enter carb other than The fuel lineGasoline needs heat to evaporate.------It gets that heat from the carburetor body.------Carburetor will be cold.----You might be looking at condensation.
Thank youYou will want to repost this in the Mercury forum. Those guys are experts.
