Curriden01
- Joined
- Mar 5, 2021
- 5
I have a seized trim cylinder. i have the old two cylinder style with the on board pump. I purchased a new cylinder and I want to swap it out. but... i’m not sure how to remove the pins that holds the cylinders in place. The confusing part is that the bottom pin looks stepped. Like you wouldn’t be able to punch it out from one side. i’ve attached pictures. Thanks.
I see that there is one pin for the top of each cylinder so that one looks like it must be pulled out.
