jakedaawg
Thread starter- Joined
- Jun 26, 2012
- 4,275
Are you skilled at the skins? I've watched Ron Covells you tube channel a bit and got some helpful tips there.Worked on my new canopy for my pickup.
3 requirements.
1. must be able to sleep across the front of the canopy.
2. must fit in my garage with an 8' high door.
3. must be able to still haul sheets of plywood without removing things.
That would require me to either have a custom canopy built or build it myself. I chose the latter.
Now I'm focusing on the skin. There is a small over cab section and rounded corners to make it more difficult. I still haven't fully decided how to secure the foam insulation inside. I plan to use 2 layers of 1" foam with the second layer held on by screws through the plastic paneling.
Here are some pictures of the aluminum framework.
