BamaBowrider 208
Thread starter- Joined
- Jan 4, 2021
- 74
Although I am sure this topic has been discussed before, I have searched the forum and still have questions. My problem is an erratic and unstable idle with this 5.7 2bbl motor. I purchased this boat in December at which time the tank was half full of unknown fuel. I added enough marine Stabil to treat it at that time. I have replaced the fuel/water separator and performed a tune up with new cap, rotor, plugs properly gapped and timing set. On the muffs, in the driveway the motor idle is inconsistent and drops down to 500 and eventually dies. I can fire it right back up and it will run for a while and then stumbles and dies.
Yesterday I topped off the tank with fresh marine non-ethanol fuel and took it to the boat launch where I could hopefully run some fresher fuel through the carb at increased rpms. It idled a little better. Not every time, but more than once when I put it in gear and loaded the motor it would die, but fire right back up. So for about an hour I ran the motor idling in and out of gear and increasing the rpms when the engine would stumble and try to die.
This morning I wanted to run it again on the muffs and record a timeline as follows;
1 throttle prime and engine fired almost instantly
Idle constantly fluctuates from 600-750 RPMs
6 min = idle increases to 850
14 min = idle starts to fluctuate from 825-850
16 min = enrichment valve starts closing, idle decreases to 750
18 min = idle decreased to 625
20 min = enrichment valve fully closed, idle drops and fluctuates from 500-600
25 min = adjust idle screw, idle fluctuates from 650-700
26 min = idle increases to 1000, readjust idle screw to bring idle back down to 700
32 min = idle fluctuates from 700-750 with occasional increase to 850 for a few seconds
35 min = idle drops and fluctuates 600-650
37 min = shut down
NOTE: the motor stumbled at the 20 minute mark, but never died today.
This is a 2007 model Larson 208 LXI, original 5.0 with a 2012 replacement 5.7 longblock. One thing I have noticed is the amount of air that the enrichment valve allows or pulls through the carb passage is very noticeable, almost loud until it starts to close. Not sure if that is normal. Anyway, I need to know where to go from here. Siphon out all the fuel and start fresh, pull the carb apart, clean out and rebuild.....maybe both??? Need some advice.
37 min = shut down
