timing marks on old merc
bra549
1975 65hp mercury outboard motor. long shaft. s/n 4043490. 3 cylinder. the flywheel has 4 dots. one on right marked #1 tdc. the one farthest left marked timing belt. no sticker. flat spot on shaft pointing to #1 tdc. timing belt broke(old age?). A. do I rotate flywheel till #1 tdc mark on flywheel lines up with plastic pointer? I don't understand where the arrow on belt pully lines up. the dot marked timing belt on flywheel is way in front of motor after setting tdc to plastic pointer. help. thanks for any info.
GA_Boater
How did you remove the flywheel to replace the belt?
bra549
i used a electric impact to remove nut off shaft. used gear puller. 5/16 socket to remove bolt off belt pully.
sidingguy
If I remember correctly the arrow should point at the crankshaft with number one clylinder at TDC.
bra549
of all people/places gave out info.. yours worked. THANKS ALOT. old merc cranked on first turn over. idle ok. THANK YOU, Bra549.
sidingguy
So glad my advice worked for you.The timing sticker was missing on two old Mercs I was given and between the two I was able to get one good motor running.
