Bad carb
XonekevinX
Hello again I have ran into another problem the carborator is bad on this boat I got a rebuild kit and thought about ordering a replacment one is there another brand that fits this engine or does it have to be oem? Attached is the numbers on it. Thanks all.
gm280
What do you suspect is bad with the carb? Is it not idling or not riving up or what? I ask because IF the carb was absolutely clean inside and out and there are no waddled out shaft hole issues, what could go bad on a carb... Most everything else could be refurbished to make it run. IDK
Ayuh,.... Welcome Aboard,...... 99% of the time, a good thorough cleanin'/rebuild is all that's needed,.....
XonekevinX
Ya im rebuilding it I just was wondering if there is another replacment besides the $350 oem version of it.
achris
More fish than mountain goat
Number on the carb is meaningless. What engine? (Year, model, serial number)
Chris...
Scott06
