kenny nunez
- Joined
- Jun 20, 2017
- 3,483
I always check the fluid and replace it periodically since brake fluid tends to absorb moisture. One day one of the brake drums started smoking so I stopped and bled off the fluid. After getting home I pulled the drums and every thing looked good. I stated actuating the master cylinder and the brakes would not retract. Turned out that the orifice in the brass fitting on the master cylinder had a piece of something in it. I guess the hole is small to delay the fluid transfer and for backing up. After drilling the hole to 1/8” no more problems and just put a pin in the coupler so I could back up.
