406Maverick
Thread starter- Joined
- Mar 11, 2021
- 46
Hello all,
Long time lurker around iboats but the past few days have me at the point that I need some help!
1st off I have an appointment a week from tomorrow at a well known shop that is familiar with my boat from the previous owner. But if I can solve it before then it would save me some $$ and I won't have to make the 2 hour drive to the dealer. Anyhoo, here it goes-
Specs of my boat-
2001 Regal lsr2100
VP 5.0 gi pefs sx-m outdrive
I just bought the boat last November- didn't get to do a water trial because it's wintertime up here. It started and ran well on muffs.
Fast forward to the last few weeks. I spent most of the winter fixing up cosmetic issues, but now am getting it ready for summer.
I replaced- distributor cap,rotor, and wires. I replaced the thermostat with a factory 160. I sent out the factory injectors and had them cleaned and flow matched. They checked out. I also disassembled and cleaned up the fuel pump system- ie removed the paint and replaced all o rings etc following the instructions by man cave mechanic on YouTube. I double checked the output and the high pressure stays dead on at 30 and the low pressure at 8-10.
So here's the issue. The engine takes about 8-10 seconds of cranking before fuel even starts flowing from the injectors and it will start. (Sometimes takes multiple cranks before it will start)
I noticed the previous owner had the throttle position sensor unplugged. So I plugged it back in. It now idles smoother, but if I blip the throttle it dies. If I rev it up slowly it revs up fine, but any sudden throttle input it cuts the fuel off. You can see the fuel immediately stop flowing from the injectors (I have the flame arrestor off while testing so I can see the injector flow) If I unplug the throttle position sensor, it idles roughly but will rev up normally and not die when I blip the throttle.
I replaced the iac valve (and have another coming just in case)
I replaced the map sensor- no change
I have tried 3 throttle position sensors
It still starts hard and will not let me blip the throttle without cutting off. I definitely appears that the ecm cuts fuel.
Good oil pressure and good temps..
Any ideas??
Specs of my boat-
2001 Regal lsr2100
Any ideas??
