Advantages (differences) in I/O and inboard
Cindy2021
We are considering buying a 34'-40' boat for mainly cruising the ICW. Seems the "cruisers" have mostly stern drives. Some of the "convertibles" ( I guess that's what they are called). have inboards (Silverton etc.) We have owned I/O before but this is a whole new adventure we are considering. MPG (GPH) is a concern.
I/O higher efficiency, higher maintenance cost
IB lower efficiency, lower maintenance cost
Cindy2021
Thanks ..... so somewhat of a tradeoff. So either for a 34' boat cruising the ICW ?? And when you say efficiency, you are talking fuel ??
Yes, I/O is better on fuel. In most cases the IB will draft less water
Consider a pair of 100 / 120 HP diesels in a trawler type boat..---- If you are just doing slow ( less than 10 knots ) cruising that would be the cheapest / hour.----Speed gobbles up fuel beyond belief.
Cindy2021
I would say 85% would be 10 knots or less but don't want that to be the max.
QBhoy
As said. Outdrive are more efficient usually. Easier option if space is an issue.
shaft inboards are less hassle and also a whole lot more of a pleasure to handle. So much more manoeuvring ability. Outdrive also can be lifted for shallow water approach etc.
Lou C
In that environment shaft drives will have much better resale value. The much lower cost of maintenance vs stern drives will offset the higher fuel consumption.
on the ICW, there are two types of boaters. those that have run aground and those that will run aground.
both IB or I/O will be fine. motors will require the same maintenance
