Select 175 bimini cover wanted. Might have canvas but could use fibrerglass cover panel that hinges over it
Scott977
I don't see spot for parts. I'm restoring one and missing rear hinged Bimini tip cover. Could use one in white. Also. Have large v6 from my StarCraft 185. Was wondering if easy bolt in. Sounds like these little 4 cylinders don't pack much punch?
GA_Boater
iBoats sell parts, but not what you're looking for.
What is a large V6?
Ayuh,..... Welcome Aboard,..... I'm guessin' yer talkin' 'bout an I/O drive,..??
The swap is do-able, but involves considerable work, such as new motor mountin' points, 'n a different outdrive gear ratio to work properly,.....
Scott977
What is a large V6?
Nobody is parting any out? Where u suggest to get that fibreglass cover. Only price missing. Large v6. Think its 4.6 largest 6 cyl. Its omc so thought maybe would mate right up but it probably wouldn't mount direct? I.all probly save to revinyl it. Bought this sunbird so had something in meantime. How do I get correct manifold for mine. Bought one said for 4.1 but not right!
southkogs
Not allowed on the forums.
What year(s) OMC? Going from a four cylinder to a six cylinder I would think you need to swap everything; engine, outdrive and all.
