Nextelbuddy
- Joined
- May 4, 2020
- 165
So last summer aug 2020 I did an engine tune up and I also as a preventative maintenance replace the water pump And gaskets with Quicksilver kit. I had no issues with the water pump no issues with leaking gear oil prior to that.
After I got everything assembled the boat was running great for probably one weekend and my engine blew while at WOT. Total engine failure and seized up. Engine temperature gauge was working never noticed any issues no overheating.
Today I finally pulled the outdrive off and pulled the old engine out and when I lowered the outdrive from trailer mode all the way down I noticed just tons of gear lube coming out of the water intake in the lower drive unit. I remember last summer for the one weekend It was running good I had to top off the gear lube reservoir twice and I didn't really think anything of it.
So I guess I have two questions what did I do wrong when I did the water pump and gasket kit in the outdrive and is it possible that whatever I did wrong that's causing this gear lube to leak out of the water intake did that cause my engine failure? Did gear lube get mixed in with water and go into my engine?
The engine was a non-vortec 5.7 350 In a 1996 Sea Ray 210. I'll drive as alpha 2 gen one.
There was no water leaks or oil leaks when I pulled the outdrive off from the bellhousing. Only gear oil leaking through the water intake holes on the lower unit.
ENG: 0F760044 457B100JS MERCRUISER 5.7L ALPHA
DRV: 0F693018 5010162JS MERCRUISER ALPHA 1.62:1
TRN: 0F650239 6010000JS MERCRUISER ALPHA TRANSOM
