898 mercruser sterndrive install new pertonix distributor
bettydirks
put conversion pertonix in mallory distributor ran fine for a while but it eatting up the cap and rotor he remoed one wire to makit work so i desided to by a pertonix flame thower distributor becuse the is wore out need hep to install not getting spark than you so much
matt167
If the pertronix is not getting full 12v, then they fry, if you leave the ignition on a pertronix ignitior ( not ignitor II ) they fry. I think your problem is lack of voltage though. points use a resistor for 6-9v, and that left in will fry the pertronix. Needs full 12v to operate
bettydirks
could the one wire that was removed be causeing my problem
achris
More fish than mountain goat
Where are you getting the supply for the Petronix? (If it was the old points wire, you need to run a new wire, that wire is resistive and will not supply the full voltage)..
Chris......
(and if you could proof-read and add some punctuation to your posts, it would make them a whole heap easier to read and understand. Thanks)
